January 19, 200917 yr Has anybody else got the Ohlins shock. If so what kind of settings have you got it set to and what kind of weight are you. At the moment I've got the Spring set to 125mm and to be honest not had chance to look at rebound. It seems ok but i think it could be alot better. Any ideas welcome. Cheers
January 19, 200917 yr My son is 12 stone,spring is set to 120 mm with the rear wheel off the ground and the damping adjuster 16 clicks out from fully in.He finds it excellent like this.Hope this helps
January 19, 200917 yr I'm 11 and half stone and i run mine at 120mm and 12 clicks out for the rebound. Works well for me, but its best to put the time to yours and get it set how you like it.
