Elf Htx 740
Any one know where I can get this oil from mail order (UK only) ?
Tried BVM today but they haven't any in until maybe next week ?
Thanks.
hey there i use valvoline mate it works a treat. I looked at montesa reccomended oils and did same enquires and hard to come by and not cheap. Dont be afraid to use another oil. Its up to you. Another way i look at it is presuming you own a car i bet you dont use manufactures reccomended oil in that do ya?
Hope this helps
Edited by sectiononecleaner
ELF HTX 740 may cost more but it is well worth it. It will last 2 to 3 times longer than any oil, making it cost effective. Changing it too often is a waste of money. Also the 4RT clutch loves it. PJ1 Clutch Tuner, for example, costs less but has has a much shorter life.
As the oil capacity is small, the oil tends to have a fairly hard life. For that reason I personally prefer to change it more frequently.
Munch supplies a good Rock Oil alternative to Elf, once in there's absolutely no need to change it as you're just wasting money.
i think you guys are wasting your money
just looked at the elf website and it gives the details for HTX 740-
"ELF HTX 740 is a monograde ultra fluid lubricant specially developed for dry clutch gearboxes coupled to 2-stroke engines."
"ELF HTX 740 must not be used in an immersed clutch"
ELF WEBITE ARTICLE LOOK HERE
For what it's worth - i was at a trial on Sunday chatting to another Mont bloke whilst in a cue for a section. We were discussing teh issue of how expensive ELF is and clutch drag on teh 315's. He used ATF (automatic transmission fluid) and said it worked a treat.
atf works ,but it does give you a noisy gearbox! any oil will work, depends on what you expect . the correct oil gives the best clutch.
posts of a commercial nature are banned on tc. :thumbup:
I've been using ATF in my old 315 having taken advice from a few people. My reasons were that I am another who believes in frequent oil changes and ATF can be bought at reasonable prices. It suits me.
I don't ride every weekend, often there are gaps of a month or more between rides for me and I do experience a sticky clutch at the beginning of each ride. Nowt that bothers me and it frees off in no time at all. No clutch drag to speak of once its warm. :thumbup:
  • 2 weeks later...
why not use elf , montesa dont say use it for no reason? they are even sponsered by repsol!!
i buy elf end of . atf is ok but atf gears are not the same nor are their clutches. sandifords use who their oil sponser is.
