Best Gearbox Oil For 315
Hi Chaps - have read through lots of discussions on this but never really got any answers. So id just like to know what people use and are happy with.
Q: What gearbox/transmission oil do you recommend for a 99 315r, other than
The Wiziard from Wales is right about ATF being possible. I also found that Silkolene Light Gear Oil 75sae was a very good oil in my 315. There was a little clutch stick once started up and cold, but soon freed off, and as the engine warmed, this sticking went and the clutch was fine with no squealing that you can get on other bikes.
Should i try and get a fully synthetic one - 75W??
PJ1 works well for me, cheap enough and easy to find.
Im my opinion DON'T use Castrol MTX I think it is, I put some in last week and it took about an hour to warm up enough to get rid of the clutch drag.
Which one would you suggest??
Two stroke gear oil (80w) - 1 litre bottle
Two stroke gear oil - light 75w - 1 litre bottle
Martin Belair suggested Mobil One synthetic or PJ 75w clutch tuner if you don't go with the ELF. We have used the Mobil stuff across four teambikes (315r's) since 02 without issue.
Cheers
why not use elf , montesa dont say use it for no reason? they are even sponsered by repsol!!
i buy elf end of . atf is ok but atf gears are not the same nor are their clutches. sandifords use who their oil sponser is.
And the only people i know who sell it are bvm wheras if i forget (which i often do) and need some in a hurry, PJ1 (or ATF I suppose) is available over the counter at 3 motorbike shops within 25 miles. (and 25 miles is good for me as i live 10 miles from any 'town' of sorts!) :D
Edited by tt5th
