250sy Front Brake Binding.
The front brake of my 250sy is binding, have altered it to the limit at the lever end in fact if i remove the lever altogether it still binds!
Sounds like the pistons in the caliped are sticking, not too hard to fix. its worth fixing as you disc will wear too!
Thanks for that ill give em a go, at least their not as hard to get at the carb; iv got that to do as well god help me!
Yep probably the caliper pistons sticking, however it is always worth checking that the master cylinder piston is moving freely before you start on the calipers.
