99 315 Face Lift
Sunday will see to that!
If i can sort out the throttle return - since i pout it back together its seems to stick open. I seem to remember buggering around with a cable shroud by teh Carb though, so hopefully that is it.
Ooh yeah, 315 owners club rule No.1 ''never put the tank back on in a hurry'' ;)
I guess you are joking - but can you elaborate - what should i look out for?
Cant wait for teh clocks to go back - does my head in having to wait until Saturday to look at/work on teh bike. (no leccy in garage)
Throttle cable needs to be routed spot on when replacing the tank. Something to check first, I found it was the cable having being pulled out of the sleeve near the carb. Just needs to be pushed in if it is.
Edited by tt5th
CHeers TT - sounds about right, although from what i remember - it looked like it WAS out of the sleeve and i (thought!) that i had put it back.
"if it aint broke, dont fix it" springs to mind
