March 17, 200917 yr Is it a big job to change bearings ?. Is there any easy way or good tips to help me. look forward to your best tips. cheers Dave
March 17, 200917 yr not a big job, just need a long stout screwdriver to knock it out with. You will ruin the screwdriver so use an old one. I have heard stories of the bearing breaking up when doing this so use a hot air gun on the hub to heat a little beforehand L Edited March 17, 200917 yr by Lee Harris
March 17, 200917 yr If you do a search you should get all the info as this has been covered fairly recently.
March 19, 200917 yr Author Thanks for the tips,im going to attack it today.....boiling kettle as i sit here with old screwdriver in hand.. cheers all thanks dave
