Gas Gas 270 Txt
i just bought a gas gas 270txt today, took it out for 10mins and it ran fine, all its power ect. but i just noticed oil* coming out of exhaust and around the sparkplug thread!.
head gasket? ran to hard?
any ideas?
is it like a thick black oil,
my sherco does it when i have just been riding it in garden on little rev's i think its called carbon where it hasnt burnt off the oil
josh
i would say its as thick as 2-stroke. the bike has now developed a nasty noise in the motor or gearbox, been out again for a hour and just when i desided to come home it started throwing white smoke out.. (alot of smoke) cut the motor off and it continued to smoke for 2-3 mins.
i have let the bike cool down and it still starts off first kick. dont know how to explain, 1st, 2nd, 3rd gear sound bubbley.. like its flooding.. 4th/5th still have stupid amount of power.
i dont have a idea mate
i dont no alot about engines sorry
someone on here will no
josh
Do a few simple things first, check your plug is tight, if not tighten it up. Done it a few times myself, done the plug in with fingers then forgot to use a spanner on it. If it is tight it could maybe do with a new o ring in there. Do you know if the bikes been sat long? Could just be burning carbon off from it not being opened out enough, happens quite a lot in the bigger engines. Try draining the fuel, cleaning airbox and carb and then using fresh fuel with the correct mix, sometimes if its been sat the two stroke settles at the bottom of the tank.
Does the bike smoke after the engines killed? If so its just carbon burning up! Check its the correct plug too.
If this doesn't work I suggest checking your head gasket and piston rings. New set of rings will always freshen up an old bike!
Let us know how you get on,
Jamie
