March 24, 200917 yr bought a new plug today, old plug was grey/white and also the wrong size. 100ml 2-stroke to 5ltr fuel.. (100ml to green fuel can) what adjustments do i need to make?
March 24, 200917 yr Gday, If it was the wrong size ( I assume the wrong length ) I'd run it for a little while and have another look before changing anything else. Was it running OK? Cheers, Stork
March 24, 200917 yr Author Its running and starting fine. But it spits its dummy out at high rpm. Old plug was to long and cheap. Was leaking oil through the the thread.
March 25, 200917 yr Whats the new plug look like? (what plug are you using?) If white, then re-jet. Here the starting point for the US based bikes. UK may be a tad richer. Ask a local dealer/rider what they run. From the Trialsp[artsUSA site: 1998/99 TX270 2000/01/02/03 TXT280, TXT280,TXT321, TXT280
March 29, 200917 yr what jetting are you running??? You mentioned an old plug that was wrong, and a new plug. What plug are you now using? What Gap?
