Montesa 348
Will the carb and front forks from a 349 work on a 348.
Yes.
Beware about front ends on 348s and 349s.
Yes the forks legs are interchangable but the triple clamps put the fork tubes at different centres. The 349 had the tubes closer together. If you are using the 349 triple clamps in a 348 consider the front wheel width and fuel tank clearance.
