May 17, 200917 yr I have a strange gearbox problem. I bought the bike 2nd hand (07 280pro) shifts up ok but to get it to shift down I need to pull the lever up a little and then shift down. I have been through the eccentric shift adjustment without sucess the problem is, the little click they talk about doesn't exist for my bike shifting up or down. The bike stays in gear no problem. Any ideas????
May 17, 200917 yr You might try replacing the top hat and shift spring. They are usually sold together and it`s cheap.
May 17, 200917 yr Author I've looked at it and it seems intact. Is it still worth replacing if it looks ok??
