May 21, 200917 yr I have just rebuilt the engine in my friends TXT 280 but i now have a problem with the clutch and could do with some advice please. The clutch lever is pumping up until it goes solid just like a brake lever i have stripped the slave cylinder and the piston is moving freely in and out. I have removed the clutch and cannot find any apparent fault ,the pushrod that runs through the engine is ok as is the button and thrust race in the clutch side. When i refitted the clutch should i have set the clutch tension springs up or as i have done just tightend them up until they bottomed out. Any ideas please
May 21, 200917 yr 5ft lb is a good starting point in clutch springs! Check the basket retaining nuts tight, and the actuator fitted over it snugly!
May 21, 200917 yr Sounds like you haven't got enough free play on the clutch lever and therefore the system remains pressurised because the fluid cannot return to the master cylinder reservoir.
May 22, 200917 yr Hi Mark, Have a check to see if you have dropped/lost the ball bearing that sits between the clutch push rod and the mushroom rod. You need to tighten up the clutch springs but be careful as the bolts can snap easily. The outer pressure plate has a line cast into the outer face across one of the holes for the springs, this hole is then to align with a spring post that has a slot in it on the clutch hub - only for alignment purposes this is. Bye, PeterB.
May 22, 200917 yr Author Thank you for the replys chaps and a extra big THANK YOU to PeterB who hit the nail on the head. I had lost the ball bearing when i did the engine strip,as Homer Simpson would say DOH New ball bearing fitted and works perfect Thanks once again Best regards Mark
