Silencer Protection
Hi, i am wondering what can i use to protect my silencer on my 300 pro gasgas, i am currently using come sticky carbon fibre but it is rubbish & keeps falling off, i don't really want to use a plastic cover, i have also looked at other carbon fibre but it seems to cost quite a bit
Any ideas would be really helpful
Cheers,
Ben.
Just get your one, warm the exhaust up, run a bead of silicon sealer (make sure its the high temp' one) on the exhaust where you want the protector to sit... then shove the protector on, hold it on with zip ties, heat her up and leave her over night to cool... remove the zipties and voila, you have one that wont be coming off anytime soon :D
Or maybe one off another bike? Worth a try :D
Edited by shercoman2k8
I have seen some use the fairly thin grade of the Ali Tread Plate, cut to size and formed a bit with rounded edges, then rivited to the muff! Looks good and tough! :D
Thanks, any other ideas would be great as well.
Cheers
Ben.
I think i'm going to use some clear sticky plastic which is quite thick, lets hope the heat doesn't wear it off as easy.
i made a rebar cage using #4 rebar crossed on 2"centers and tie wired with a premium coat of rustoleum paint and tie wired it to the frame looks great!lite weight as well!forget the bling dont crash!
