May 31, 200917 yr has anyone had any problems with the magura clutches as mine seems to be leaking fluid from where it pulls the cable (the brass nut). i have'nt taken it of yet as its not loosing much but will have to soon but me and spanners are a bad mix. also is anyone just running on a cable pull ifso whats it like???? thanks Rod.
June 11, 200917 yr The Magura is an add-on kit that can be obtained for many bikes. That also means parts are available, so I'd expend the effort to fix it. I've owned the 125 version with cable clutch, and spent some time riding the 175 with hydraulic clutch. I would not go to a cable clutch.
