Air Cooled /water Cooled Compatibility
Will the hydraulic Bottom end of a K-Roo be compatible with the top end of an air cooled engine?
Edited by der italian trials
The section bottom end is...but I could not get a 305 cylinder on a kroo bottom end. maybe a one off? i dont know
Thanks for the info Lee. Am I right in thinking only the '94 K-roo engines that have hydraulic clutches?
Hamish
yes and of coure the later section.
but be careful, even if the barrel will fit
the kroo clutches were the first hydraulik ones are they were and are cr!p
this is why nobody wants to buy them. they never was a fix...except to change cases and go cable pull
Edited by Lee Harris
der italian trials what is the reason for this interesting combination?
i had a 245 years ago and the back lug that clamped around the swing arm pivot had broke! i just chopped the back end off some newer watercooled casings and had them welded up!
My engine has seen better days and there was a kroo for sale and I wondered were the two compatible as outwardly the cases looked similar.
Also seeing the 300 at the Scottish with a hydraulic clutch I wondered what bike they were off.
