Brake Pedal 4rt
Hey all,
Snapped my standard montesa 4rt brake pedal yesterday on a big tree stump. Just wondering if anyone can recommend a after-market replacement or should i just buy an OEM one as in all fairness it has taken some hard hits without bending or breaking until now.
Thanks in advance
on the subject of mont rear brake pedals. I had a crack on one and absolutly loved the shape and feel of the rear brake. wonder if i could get one to fit on my gasser....
Tom
Scott,
TEC-Cycles here is So. Cal has a great replacement break pedal that my son has been unable to break over the last year. :wacko:
It's just the right length and has a folding tip, and roller bearing mount. It's $145.00 but well worth the price.
www.tec-cycles.com
Regards,
Rich
Thanks for the replies guys.
Quite tempted by the v-mar and h and d one. Do these pedals feel any different from the standard one? Where can I purchase them from?
Thanks
We use the aftermarket Apico brake lever, cheap as chips so it doesn't matter if you knock a few off, especially if anyone is doing the SSDT. Rocks are a bit of a hazard!
Big John
Big John
You can of course fit a Clake and not bother with the rear brake pedal at all.
I've used a H&D one, a Sherco one & a standard pedal. I'd rate them in that order.
Standard one is soft as **** & bends very easily, the further it bends the less back brake you have. I've also snapped several.
Sherco Pedal is a straight fit & is good to use, very compact, I never bent or broke one. Downside is there's no upward bump stop, an upward knock & the pedal hits the casing, I never did any damage on my bike but I didn't fancy doing an SSDT with one on.
H&D Racing pedal is the dogs B*****ks & well worth the money. Compact & hidden away but easy to find with your toe end. Wish I'd thought to try it on the Gasser instead of flogging it.
Please note this in not an advert for Marky Boy's products :D:wacko: But the pedal is bloody good.
Horse dead and flog re arrange in the right order.
