Rev 3 Clutch Lever Info Required Please
Hi There
I crashed today and broke the clutch lever.
No Problem thinks I as i had a spare back in the van...........BUT......
When i came to fit it i found i had lost the rubber boot assembly which i think looking at the brake lever must contain some kind of push rod, because when i fitted the new lever, even with the adjuster right out it would no where near engage the clutch.
Can someone just confirm what i need to get hold of as i do not have a parts book.
the bike is a REV3 125 2005 Model.
Many Thanks
Geoff
If it is anything like my 250 you'll also have the same thing on the front brake so you can have a look for reference. I've no idea what it's called but every time I've needed something I've called Lampkins and they've got me what I need very quickly.
Also Lampkins have all the engine and parts lists on pdf file on the website,also pricelist,which is handy
