Ossa Mag Cover
Why do the ossa mag covers seem to crack or fracture so easy and can they be repaired?
They usually can be welded, and I assume you threw a chain to break it?
The reason the case breaks is that the clutch arm puts a trmendous pressure on the casing. If the bolts holding the case, especially the one behind the sproket the flex will break the alloy case.
And yes they all can be welded and most are.
