September 16, 200917 yr Hi, I'm sure this topic has been covered before but I can't find it so does anyone know a good starting point for jetting a keihin carb for a 125 pro? The carb is off a 300 pro so will I also need to change the silde which is currently a 3.5 and the needle which is currently a jjh? Any recommendations / experiences would be much appreciated Cheers, Mark
September 16, 200917 yr the 3.5 slide will be fine, as the 300's should be using a 3 slide instead. the needle will be perfect, jetting will be fine also, i used to use standard jetting on my old 125 & it run perfect, to be honest i wouldn't change the jetting as long as the bike runs ok. What main Jet & pilot jet is in the carb at the moment? Edited September 16, 200917 yr by GasGasben
