Sherco 2010 - Video
This kind of system or similar has been used on model aero engines and also some modern scooters where the tank is below the engine. Usually uses a diaphragm operated by the pressure pulses in the crankcase. Sherco's system may be different though.
Wayne....
Sounds similar to the scorpa 4 stroke
Petrol stops on The Scott will be fun!
A few cranked funnels will be required I would think.
Hey I said that two days ago!
Sorry to repeat your post Dabster, however I do agree filling up is going to be rather fun as how do you know how much fuel is in the tank and when do you know you are short on fuel?
I think it is a slightly negative point not been able to see the fuel level easily, it's just the same as the gasgas and beta though.
It could be better for the scott and the scottish as they nearly always overfill the tanks anyway, at least with the tank filler being where it is you won't get petrol at over your b******s and it won't destroy the tank stickers either.
You beat me to that one!
Same as a friggin gasser or mont! :ph34r:
Dont agree with you on that one Copemech . I have had a Mont and could check the fuel level by peering down the tank with the filler cap off.
Now I am only looking at pictures and may be different when I see one for real but with the Sherco the filler cap is 90 degrees to the tank and is it possible to remove the cap and look down the tank to see how much fuel is left?
One way or the other it's going to be awkward to fill, so a flexi funnel might be required.
I know there's a trick you can do on a Gassa with a clear tube, run up alongside of the frame and connected to the fuel tap, which makes a good fuel level indicator....maybe the same trick would work on the Sherco somehow?
Best of balance.
Neo
That is why there is a "Reserve" position on the fuel petcock.
Get over it, it is not that big of a deal.
John is right, I stand corrected, meant Beta! :ph34r:
But for those interisted, I could easily run a slim plastic tube down it, cap it with the finger and tell you the level. Could also calibrate the tube if need be.
Damn, that is what we do in aircraft, when one really wants to know when those unreliable guages are lying to you, what a pain!
Pity poor trials riders that never managed to calculate their average run time, in LPH, as they may have no clue!
If one needs to get specific, it can be done!
Edited by copemech
I bet it will be a sweet ride.
The Rad looks a tad exposed on the sides.....
Production rad is narrower.
Much tighter steering lock without wraparound frame in the way
Bike is much slimmer in the flesh than in the photos.
:ph34r:
At least the old JCM fuel tank was transparent and easier to fil!!
It was also 12" higher, made of plastic and the shock rubbed through it!
