Tips To Fitting Fork Seals Please?
Hi have a 95 beta techno 250,gonna give it full service have all the parts.Not too worried bout tackling the bearings,piston rings or bakes as have done all these before on other bikes. Never trails bikes tho so anything to watch out for? I've never replaced front fork seals tho so hoping for a guide on that please. Thanks in advance.
Gday,
Search around the Sherco forums for the fork seal job. They are the same pretty much. Good luck bleeding brakes - also search for that topic as you will probably need it.
Cheers,
Stork
Yeah seen a couple threads about the brakes alrite, not looking forward ta it! Cheers!
Hiya,
Start back with a similar age techno about 12 months ago. Same as you, started working thru it but it became a real money pit. Brakes were a nightmare as the parts were quite pricey, but I did manage to get them into a servicable state. Pistons were seized in the calipers so the only real way to get them out was a cut down banjo hose and an air line! once they were split they were quite straight forward. Ran the bike for 6 months but did not find it competetive as it needing heavy maintainence to keep it going. Sold it on ebay and paid a bit more for a 2004 Rev 3 (only
Hiya,
" in hindsite I probably bought a bit of a dog!"
Easily done in a moment of enthusiasm.
