Montesa Cota 123 Fork Disassembly
Can anyone tell me how to get some early Cota 123 -27M front forks apart. This set have small round steel bottoms. I have released the bottom bolt removed the top cap, springs & damper rods. I have unclipped the fork seal circlip & inserted a dummy rod in the bottom axle eye. Then carefully laid the fok bottoms in the vice using the axle to stop fork leg being pulled out of the vice. Using the tried & tested hammer action on the stanchions including the use of heat around the fork seal area - nothing moves. Finally one fork seal popped with the heat but still can not split forks apart. Any ideas?
Hi
Put the hammer away;)
You need to unscrew the top Seal/Bush housing (TEL 189.518), Those should be Telesco forks at least on 28M which come apart differently to the later Betors.
Wayne....
Edited by wayne_weedon
Many Thanks
Just as well you stopped me before i went much further, i will try to "unscrew" the top portion of the bottom of the leg. This should certainly do the trick, the drawing is of great help. Should still prove interesting getting these off, as there are no flats on this item to get hold of.
Heat helps. Try to heat the ally leg just below the steel carrier, I use a hot air paint stripper. There should be an O ring in there too.
I use a lathe chuck to hold them for unscrewing, but you should be able to come up with something.
Wayne....
Hi Wayne
Many Many Thanks, Job Done.
Your'e welcome. Hope the hammer didnt do any damage! Are you just doing a clean/rebuild and seal change?
Wayne....
Thanks for all your help. I am trying to fit the fork set to a Bantam. I have got the forks apart. All parts shot blasted. Next hurdle is to determine what steering bearings to use. Not sure what the montesa used, looks like cup & cone like sammy miller sells? Difficult to find possible taper bearings that might fit the Bantam or Montesa. Thinking of trying to use the complete fork set as is or I understand the trick is to press fit the bottoms into period truimph heavy duty forks or something. Bit stuck at the moment also trying to source the montesa lip seals 7.5 x 42 x32 mm. In case you throw your hands up in horror that I am ruining a perfectly good set of montesa fork,s I do also own a montesa 200 so can't be all that bad.
32x42x6 or 7 are commonly available as a standard dowty style lip seal.
Yes would of been cup and cone.
Wayne...
