315r Decals
i've had a root around on ebay and other than sandifords for the genuine ones is there anywhere that i can get a set of decals for the rear mud guard and the front forks?
Hello Serious,
Get the part numbers from your manual, or from the Apex parts book
Then try your local Honda dealer, or order from Sandifords if they have any stock left, or you can order online from CMS in Holland - I have used them, but before the Pound/Euro rate was crap, so may be expensive now.
Good luck!
Hi Serious,
First you need the part numbers from your manual or from here
Then you can order from Sandifords if they still have any left, as they have stopped distributing Monts, or try your local Honda dealer, or order online from this lot in Holland - I have used them before - and you can get prices before you order.
Good luck,
Highscore
thanks for that! i tried both numbers in that dutch site but they only have the decals for the front forks at the moment. might try to get the later decals instead.
