Beta Techno Crankshaft
I've a 250cc Beta Techno (1999), that i lent to my cousin (some time ago now) where upon he broke it at a trial. Among the things that broke, the crankshaft snapped in half. Having been paying off my student debt mountain, i haven't been overly rushed to fix it, but i now spy on ebay (here) a 94 techno 250 is being broken up, and the crankshaft is going relativity cheap (Beta UK want circa
Gday, according to my Beta parts manuals the 2 cranks have different numbers. It may pay to check with a dealer to see if the 99 crank supercedes the earlier one. The pictures look similar which means nothing of course. Which part of the crank is broken? If it is the pin, that is replaceable relatively easily.
Cheers,
Stork
it's the shaft that the flywheel sits on that is broken. my old man thinks that if the bore and stroke of a 94 is the same as a 99 (72.5mm by 60mm) it should be usable... (all sounds way to technical for me!)
Might be worth blasting an e-mail to www.usbeta.com to see if Ron Jr knows for sure, or Ron Sr! He has lots of experience with these! :biggrinsanta:
Never a borrower or a lender be and through your life you shall be free. You need to check it out with John Lampkin (he aint a bad sort & he will surely help you out re identification problems) I think ther was no change untill the Evo models but thats just think . Neccesity being the mother of invention you need to understand what is what for yourself. (sorry to preach but I.m an old fashioned old git) I really hope it goes well for you
thanks for the replies guys, i've ordered it it. phoned up John Collins MCs in south wales (who wasn't sure) and beta UK (who weren't too sure either) but we'll see if it does fit. I'm have to admit i'm in no way mechanically minded, but my old man is (but not very computer minded at all) - so we get there in the end.
Gday, they use the same Crank bearings by the look of it, so you might be in luck.
Merry Xmas,
Stork
  • 6 months later...
we got the 94 crank in the end, it doesn't fit exactly but my old man and an engineering friend of our re-engineered it to make it fit and it worked
