Ecu Settings For 2007 4rt
A friend's 2007 4RT Repsol Replica seems to have a far more instant throttle response compared to his previous 2005 standard 4RT. The result is far greater difficulty in finding or regaining grip.
Does a 2007 4RT Repsol Replica have different ECU settings compared to the standard 2007 & 2005 bikes?
With the CD and interface cable available which map(s) should the average club rider really load?
At the moment we do not know which map is currently loaded, a previous owner may have had the ECU set to a non-standard map already.
There is every chance this request may be going over old ground but there may also now be greater real world experience to hand.
The 2006 repsol had a programmable ecu. This was not std on the 2007 repsol. (we have one of each).
So if your 2007 has a programable ecu it was an add-on. so I would guess they loaded a 'hot' map.
no big deal writing /loading your own maps &/or loading a more standard one from the cd.
Our std 2007 can't be programmed and it is fairly quick to respond (depends what you want).
Maybe they have fitted a fast action throttle on the bike ?
They all have fast action throttles, or should have.(oh no they don't)
Edited by Nigel Dabster
our survey says, na nah.
A mate of mine had an 06 repsol, it definitley came with a slow throttle.
can I smell gin again ?
Gin? I think the daft bugger's been on the meths.
