09 300 Pro Gear Oil
Hi which oil do i use?
Have been told 2 different types
ATF - which type
or 10W40 ?
Which type is correct?
Cheers
ATF - which type
or 10W40 ?
Cheers
ATF 10w40
10w40 is the viscosity, Atf with that viscosity will do, some run 15w40.
Any synthetic 10w40 oil will do though.
I may be wrong, its certainly happened before but
ATF is not 10w 40
atf = automatic transmission fluid as recommended by Gas Gas UK, needs to be dexron 3.
10w40 is motor oil not atf
ATF - which type
or 10W40 ?
Cheers
We've generally found that the Type-F ATF works well in the 06' on up, with the
thinner Belville springs. It's inexpensive so you can change it often without burning
the bank account.
10W-30 will also work, but I've found that the ATF is a little better suited for Trials
transmissions and wet clutches (light weight, about 7.5, with anti-foaming and
shear additives).
Jon
Do NOT use synthetic oil
GasGas recomomend ATF Dextron III.
I use Castrol TQD (same stuff)
What about a 99 Gas Gas 370?
Thanks,
Terry
Thanks,
Terry
Hi Terry.
The "370" was the 1996 model (actually a 338cc engine) but the same basic engine as the 1999 models, so you would use about 650cc's of Dexron ATF.
The 09' engine is the "Pro" and a different engine design than the 99'.
The reason we recommend the Type-F ATF, over the Dexron ATF, for the 06' up is that the 06' on up uses a thinner Belville spring in the clutch and is
slightly more prone to slippage and the Type-F is a little more temperature tolerant.
Jon
Jon,
Thanks for the info, so do I not have a 370? The vin is 3799 after the inital letters so I figured it was a 99 370 even though it was advertised as a '99 320.
Thanks,
Terry
Hi Terry.
Jon
I got an '09 250 and use Castrol Qtf and use 400ml from empty, make sure your oil level is halfway up the window. It comes in 1 litre bottles so best to buy 2 bottles that way you get 5 oil changes for around
Edited by Lightfeet
Jon,
Thanks,
Terry
Terry, you have a "321", the larger displacements had the "37" designation on the VIN. I have a 99' 321 in the shop with the "VTRGG3799....." as the VIN.
Jon
