February 7, 201016 yr I just bought an Evo 290, was wondering whether the coolant still causes problems with the casing like the old betas, and if so should I change it out for another type of coolant such as motul? Or is this no longer a problem?
February 9, 201016 yr I had the same question that you asked so i dumped the pasty green factory stuff and refilled the cooling system with fresh antifreeze of a known type. No questions now! Edited February 9, 201016 yr by Liviob
February 9, 201016 yr Just for safety's sake I'd recommend using a propylene glycol based coolant like Engine Ice or Silkolene Pro Cool. If the engine does have magnesium parts better to be safe then sorry.
February 9, 201016 yr Just for safety's sake I'd recommend using a propylene glycol based coolant like Engine Ice or Silkolene Pro Cool. If the engine does have magnesium parts better to be safe then sorry. The owner of a company called two2cool says that engine ice and the typical auto coolent use the same propylene glycol. Edited February 9, 201016 yr by Liviob
February 10, 201016 yr Ethylene glycol is traditionally used in automotive systems. The real benefit of the premixed propylene glycol coolant, aside from non-toxicity, is it uses deionized water which significantly cuts down on the chemical reactions that are corrosion. Tap water is full of chlorine and fluoride and iron and metallic salts which will pass right through you but wreak havoc on your engine.
February 11, 201016 yr Anyone know how much coolent will be required for a 2008 rev4, Sorry for going off track
February 12, 201016 yr Should be similar to a Rev3 which is about a quart from empty. Just pour it in till it stops taking it. Squeeze the hoses to work out air bubbles in the system. Then run it a while and after it's run for a bit let it cool and check the fluid again. Fill and forget.
February 13, 201016 yr Sorry for being a thick Welsh man, in proper english how much is a quart?? dont know about the quart convertion but a rev 3 will take 600 ml
February 14, 201016 yr Heh heh We call it the "english" system of measurement but they don't use it in England. Pardon my forgetting.
February 14, 201016 yr Was just going to ask the same thing I'm picking up an 09 250 Evo on monday looking to do all the oils and coolant before riding it...Great feedback thanks guys ...
June 26, 201016 yr I've just drained my coolent on my Evo and got some Silkolene Pro Cool but I don't know if it is remix out of the bottle it doesn't say or does it need diluting ie 50/50
June 27, 201016 yr As far as I know all the propylene glycol coolants are premixed and ready to use. From the Silkolene website PRO COOL Advanced, all-season engine coolant based on propylene glycol for reduced toxicity levels. Formulated with 50% distilled water
June 27, 201016 yr As far as I know all the propylene glycol coolants are premixed and ready to use.From the Silkolene website PRO COOL Advanced, all-season engine coolant based on propylene glycol for reduced toxicity levels. Formulated with 50% distilled water Thats What I thought but wasn't 100% sure . Thanks Evoboy Edited June 27, 201016 yr by evoboy
