2001 Rev3 Kill Switch
Hi guys,
My 2001 Rev3 came without a kill switch, so I have set myself the arduous task of fitting one, and have bought is a Yamaha style, 2 wire switch.
Now I have read loads of different posts about this, but cant find one that matches what I see.
(I can see no loose black and white wire that many seem to mention)
Any help or suggestions would be gratefully recieved.
Thanks!
Coming off the stator up to the CDI module connector there will be a harness with four wires that go to the CDI connector and a yellow wire that splits off for the lights. The four wires to the connector are, Brown = System Ground, Red = CDI charge wire, White = (I think) CDI trigger microcontroller power wire, White with a black stripe = (again a guess) actual trigger. Coming off the stator side of the connector will be a wire that originates from the CDI box and doesn't go down to the stator. That is your kill switch wire. Wire one side of the kill switch to that wire and the other side to one of the screws that mounts the ignition coil.
