Knocking Noise
I have recently noticed a knocking noise on my 02 280pro (which i now know it is due to txt/pro differences discussion). It appears when the engine is revved faily high then the throttle is shut off. The shop i bought it from said it sounds as if it is running lean. I adjusted the carb and the noise died down but the engine kept stalling. The noise appeared to be coming back when the bike eventually stopped due to being out of fuel. Another rider said his Gas Gas used to make a similar noise when it was running low on fuel. Anybody else had a similar experience?
Cheers Neil
I second what HondaRS has said. I found my '02 Pro was lean on the pilot. I'm near sealevel and 15-25C temps.
