triton Posted January 3, 2005 Share Posted January 3, 2005 Hi Happy New Year to you all. Can anyone tell me how much extra clearance a Miller Swingingarm gives compared to the standard Cub one. From the rear face of the s/arm crossmember to the front of the rear wheel axle slot measures 13 inches on a standard cub. I rode a trial on Sun but couldn't complete it, due back wheel clogging up . conditions were bad, thick mud and dry leaves. Oh no more expense!!! Quote Link to comment Share on other sites More sharing options...
subira Posted January 3, 2005 Share Posted January 3, 2005 Don't forget that due to where the drive sprocket is located clearance on the chain will always be tight. If you mod the swinging arm, you should get the engine moved over as well, might also need the wheel pulled across a bit to. Ray is a really good guy to speak to. Quote Link to comment Share on other sites More sharing options...
