Rear Shock Beta Evo
Hello,
does anyone knows if the rear shock of the beta evo is the same one that is used on the sherco?
best regards bob
I am not familiar with the Sherco shock. Why do you ask?
i ask becoure jitsie sells a modified olle shock for beta at a fraction of the cost for a ohlins, so i wonder if i could fit this on my sherco
anyone knows the lenght of the rear shock? a sherco's is 26 cm
best regards bob
Maybe you can ask Jitsie if the dampers are the same dimensions. I know the spring on the Beta is tapered. Even if it will fit the Sherco. It may not be valved corectly due to a possilble different linkage leverage ratio or have the correct amount of stroke. Do they make one for the Sherco?
Edited by Liviob
as far as i know they only have one for the beta but i will inform if they can make one for the sherco
best regards bob
