March 14, 201016 yr Ive just bought a replacement gear lever and was wondering how easy they are to change? Is it a case of taking off the crank case cover or do i need to drain the oil and start fiddling with the clutch and gears? Clueless! Any help would b appreciated!
March 14, 201016 yr there is a small bolt on the gear lever just undo that and the lever will slide of the splined gear shaft really simple and no more than a 2 minute job
