Jt35 Stops Running After 2-3 Mins
Hi there
My jt35 stops running after 2-3 mins , if not reved up?
only will then start if i have the choke on, then turn it off even if hot
bike has been laied up for sum time,put in new fuel
there are two screws on the carb one small , one that is spring loaded what do they do?
kind regards
wayne
You'll need to clean your carb out I reckon. The two screws, one with the spring sets the idle speed - you could try turning that up - and the other one sets the idle mixture.
