bertie Posted April 23, 2010 Share Posted April 23, 2010 Im restoring a yellow 350 cc ossa gripper but it,s misssing the tank / seat mounting bracket which should be welded onto the frame , has anybody got any photos so I can weld the correct bracket back in place , also how long is the chainguard rear mounting bracket ? I want to fit some new alloy bodied Betor rear shocks but the bottom eyelet is only 12mm and the lugs on the bike are 15mm any ideas ? Thanks for any help Bertie Quote Link to comment Share on other sites More sharing options...
anyoldiron Posted April 23, 2010 Share Posted April 23, 2010 You could try pushing out the 12mm sleeve and pushing in a 15mm sleeve.Its worked for me. Quote Link to comment Share on other sites More sharing options...
bertie Posted April 25, 2010 Author Share Posted April 25, 2010 Hi , thanks for the response , did you buy the bigger spacers or have to make some ? I noticed you live in Mid Wales anywhere near Knighton ? Thanks Bertie Quote Link to comment Share on other sites More sharing options...
