Techno Clutch
hiya all what is the best way to bleed the clutch on a techno ? can it be done with a syringe? cheers mick
Edited by skippy1234
Hi, i did mine on sunday, tried bleeding it normaly and just couldnt get any feeling on the lever so then tried with a syrindge and i got fluid squirting out everywhere. then realised that the spring in my master cylinder was nt returning the piston back far enough for me to bleed properly so for a temp fix i stretched it abit put it all back together and in a few grabs of the lever my clutch felt great again!
if you wind your screw all the way out then just pump it with the bleed nipple closed, it draws all the air up.. or does with a gas gas
