Race Sag..
Gas gas txt250..08
Just TRYING to set my suspension up and i dont want to get it wrong so i came for some advice.
bike in the air the front suspension measurements is 16.5cm (6.5inch)
just the bike 15.2cm
and me on the bike 11.3cm (4.5inch)
so for the race sag going in 1/6th i need to raise the bike 1 inch when im on the bike..
How do i do this..more oil? more rebound, compression...i dont know...
Gday, all sag is adjusted with the spring pre-load adjuster. A lot of folks get these back-to front - in that they try to adjust sag with the damper and "feel" with the spring. Front forks - the adjuster is on top of the fork/s, rear shock the adjuster is the large ring under the spring.
Cheers,
Stork
