May 28, 201016 yr Apologise if this post has been done to the death but need to know cheapest and best place to get my rims powder coated in the north west Thanks for any responses I get
May 28, 201016 yr Loads of powder coaters, I regularly use these - Flare Powder Coaters, in Warrington, and Alchemy, in north Wales/Flint. Can supply numbers if needed. Rims can be masked up if needed, you can buy 3M masking tape for this application, just remember to tell the coaters, as they'll run the ovens a bit cooler !
May 28, 201016 yr Author Loads of powder coaters, I regularly use these - Flare Powder Coaters, in Warrington, and Alchemy, in north Wales/Flint.Can supply numbers if needed. Rims can be masked up if needed, you can buy 3M masking tape for this application, just remember to tell the coaters, as they'll run the ovens a bit cooler ! Thanks for the response What do you use masking tape for - what are you masking off? Can you get the hubs done as well? If you do strip down how / who do get to respoke / true the wheel again? Cheers
