nath15804 Posted June 29, 2010 Share Posted June 29, 2010 Hi, Recently bought a scorpa easy 250 rotax. The carb needed setting up the seller said as it wouldnt start. set the carb up so that it starts but as soon as you give it half throttle, the bike decides to rev quite high randomly until you hit the cut out switch, any ideas what could be the problem?? the carb is returning though, so its not that cheers nath Quote Link to comment Share on other sites More sharing options...
godzilla Posted June 29, 2010 Share Posted June 29, 2010 Throttle cable could be too tight or the throttle could be sticking on the bars? Quote Link to comment Share on other sites More sharing options...
nath15804 Posted June 29, 2010 Author Share Posted June 29, 2010 No mate, as i said the slide is going back to the correct position. Quote Link to comment Share on other sites More sharing options...
