July 12, 201016 yr Hi this is going to be a tricky one. I have a 94 Beta Techno with the upside down forks on it. What i want to try to do is find one a techno in a later year that has the conventional fork setup and swap the whole front end assembly. A: is it possible to do so. B: where should i start looking. Reason im looking to do this is to stop loosing my front brake due to leaky fork seals. and gravity is not helping with the matter. My current forks are in great condition with no scratches in the forks at all. The seals are just old and are about to be replaced. MY seals have not been replaced since the bike was new. If the seals are changed regularly does this solve having a front brake coated in fork oil?
July 13, 201016 yr Sure you could switch out the yokes and forks from a 96-99 I suppose, but you still have to maintain the forks with oil changes and seals. I always had about the same luck with either type of fork.
July 13, 201016 yr Author Well im taking over the bike from its last owner and am cleaning it up and trying to maintain it better than they did. This bike is also in exellent condition as is. Like i said this is the first time the forks have been off the bike since new and a new set of seals and oil for them. Edited July 16, 201016 yr by beta_trials
July 13, 201016 yr I wouldnt spend the money for a fork swap unless the forks are bent or unrepairable. Fixem so they hold oil and save your money for a newer bike. The way your riding your going to want a more current bike in the near future.
November 25, 201015 yr i did this on a beta zero you will find that rev3 yokes will fit then you can fit most fork legs of rev3 dimensions i used gaser 04 legs rev3 caliper and the zero wheel looks more modern as i dont like the look or charicteristics of usd,s
