Milky Gear Box Oil
Hi can you help me i have a 05 rev 3 and the gear box oil is contaminated with anti coolant, had the water pump cover off and found the corrosion on the case all round the water pump seal. have see the aluminium case on e bay but none there now, was sure the person selling was a shop in the uk. can you lot help thanks
Dont bother repairing, give Alan a call at Feet up, he will supply all the bits you need.
At least you know its done then.
  • 2 weeks later...
Thanks you lot, have found that thay can be fixed (mine was bad) found a better sealant and cheaper. most engine have aluminium caseings and have found thayhave seler just for aluminum or mag, the sealer i have used is mercedes sealer and set like sticaflex. will get the part number of the one that i used and post in the mor. have used on a trial and up to now ok. thanks seth.
