gii Posted August 6, 2010 Share Posted August 6, 2010 I want to change the fork oil in the Cerianis fitted to my Cub They have 35mm dia stanchions and are around 31" long spindle to fork tops unloaded What sort of volume and weight oil should I use as a starter. The oil that's in is red so I'm guessing it's ATF. Quote Link to comment Share on other sites More sharing options...
db133 Posted September 10, 2010 Share Posted September 10, 2010 (edited) I want to change the fork oil in the Cerianis fitted to my CubThey have 35mm dia stanchions and are around 31" long spindle to fork tops unloaded What sort of volume and weight oil should I use as a starter. The oil that's in is red so I'm guessing it's ATF. I understand it to be 200cc/6 3/4 fl oz ATF/5w Edited September 10, 2010 by db133 Quote Link to comment Share on other sites More sharing options...
gii Posted September 10, 2010 Author Share Posted September 10, 2010 Thanks. Quote Link to comment Share on other sites More sharing options...
