September 22, 201016 yr just got a 98 gas gas jtx. i have drained the oil and found 900 ml in the engine. is this right, if not how much oil would you recommend?
September 22, 201016 yr just got a 98 gas gas jtx. i have drained the oil and found 900 ml in the engine. is this right, if not how much oil would you recommend? We've found that 650-700cc's of Dexron ATF works well in that engine. Jon
