September 26, 201016 yr Hi Guys Recently bought a Beta ALP trail/trial bike and it's a fabulous little bike & in great condition other than a fairly worn back tyre which initially I wasn't too fussed about but spotted an as new tyre on Ebay the other day and won it for
September 27, 201016 yr Author You can use a tube in that one no problem. Excellent, thanks, I'll have a go at fitting it in the week. Do people still use washing up liquid to aid the tyre over the rim or does this promote tyre slip on an off road bike?
September 27, 201016 yr Excellent, thanks, I'll have a go at fitting it in the week. Do people still use washing up liquid to aid the tyre over the rim or does this promote tyre slip on an off road bike? I use a water/ washing up liquid mix, it will help the tyre pop on the rim, you may need up to 60 psi to get it to seat properly, watch the bead and make sure it's even round the rim. Also don't pinch the tube, and fit with the arrow in the right direction....
September 28, 201016 yr I run a tube in the rear of my 01 rev 3 and it has a tubeless tyre and rim and I run very low pressures and ride rocks a lot and I have never had a puncture. There also seems to be no disadvantage to running a tube in the rear unless of course you are worried about saving weight
October 6, 201016 yr most of the bikes i have owned ahve had tubeless tyres but have been fitted with tubes for extra security? if you want you can get an uber thick (whale foreskin) enduro tube that you would prob struggle to cut with a stanley knife.. prob not best for competition use but ok for tinkering around on... cheers
