October 1, 201016 yr Anyone fitted a Hebo Auxilliary fuel tank to an EVO. Just received mine from TED with the instructions in Spanish and German. Any help greatly received. DJ.
October 1, 201016 yr its really easy and it does work. remove number board or light , clip tank to forks, the pipe with black vent clips onto cables the other pipe is the feed and the vent pipe from the bikes filler cap pushes up inside this pipe,( Yes it does fit , and it does work), it draws the fuel from the aux tank first ,then the normal tank, used one last year on evo great thing, never any problem. one thing to remember is your number tapes onto aux tank, if raining washes off, you need some clear covers to wrap number in then tape it on.
