November 2, 201016 yr Right guys at the clutch basket i have a wobble Seems that the input/output shaft not true Does this make a difference? Clutch is snatchy and dragging and slipping Any Great ideas?? Marty
November 2, 201016 yr Had the same wobble (see http://www.trialscentral.com/forums/topic/24519-b40-clutch-basket/ ) Had reasurance from Pat Slinn and others, just forgot about it. Make sure you set the clutch to lift equally by kicking over with casing off and clutch pulled in to spot wobble.
November 3, 201016 yr Author thanks It was just that the primary chain seems to go tigh or loose depending on the position of "wobble" there also seems to be a very slight movement on the gearbox sprocket aswell I put a impact gun on the clutch shaft and spun at highish speed to see the wobble Marty
