4rt fork oil showa ss05
hy anyone no where i can pick up some showa ss05 fork oil for 4rt or and oil that same regards ste
Hi
I'm pretty sure that is just a 5w fork oil, so any off road dealer should have that on the shelf.
hope this helps.
cheers
Hi
hope this helps.
cheers
thanks
thanks
The best thing to do is match the viscosity, not the weight. The "weight" can vary drastically with manufactures. Find your oil on this chart, then find something close you can get.
http://www.peterverdonedesigns.com/lowspeed.htm
Showa SS-5 is 15.68 cSt @ 40C find something on the chart you can get that is close.
also how much oil do i put in each fork for 4rt it dosnt say in manual regards ste
You are going to level, not quantity.
Right leg gets 38mm (approx 405 CC)
Left leg gets 87mm (approx 410 CC)
Left leg is measured without spring. Pump leg 8-10 times then measure.
All levels measured with leg compressed.
Shout if you need anything else.
thats what i dont get how do you no its 38mm or whatever regards ste
I use one of these.
It is from motion pro. You can rig something up with a tube and a turkey baster if you need too.
The slide is adjusted to the fork oil height (distance from the top of the fork tube) you need. Fill the fluid up to a level above what you need, suck out what you don't.
This is done with the fork full compressed and spring removed if there is one.
Edited by mud400
OR, you could just very carefully fill it up with a scale down in the tube to measure the level. Stop when you hit desired level.
Edited by mud400
hy im struggling with the oil levels in the manual its in cm3 is that the same as ml
Yes CC (cm3) = mL
Yes CC (cm3) = mL
just a daft quest which way does the seals go back in wich way does the spring side go
Did you take it apart or someone else?
Re-assembly is the reverse of dis-assembly :thumbup:
Spring side goes into the leg.
