December 28, 201015 yr hi i bought a 2003 gas gas 70 rookie for my boy for christmas and the carb has started bogging down when you rev it quick also when trying to get up hills theres just no power there it boggs out ive taking the carb off and cleaned well with an air line butt its still doing it can anyone help me with this problem
December 28, 201015 yr Have you properly adjusted the fuel/air screw? Could be too lean. Also, have checked for air leaks? If the bike was running properly and developed the isse, I would check those items 1st. If it always did this, I would call your dealer and verify the correct jetting. Edited December 28, 201015 yr by laser1
December 28, 201015 yr Sounds like a mixture problem to me too, mine is an 05 but you could try these settings. I have the needle set to the richest (the bottem notch) and the air screw is wound out 1 and a quarter turns with the fuel wound in 5 and a half turns. I know it might not be right for your bike, but it could be a good place to start. let me know how you get on Edited December 28, 201015 yr by kippa1992
December 29, 201015 yr hi i bought a 2003 gas gas 70 rookie for my boy for christmas and the carb has started bogging down when you rev it quick also when trying to get up hills theres just no power there it boggs out ive taking the carb off and cleaned well with an air line butt its still doing it can anyone help me with this problem Go to: http://www.trialspartsusa.com/tech.html and click "Carb settings" and the spec.'s for the 01-05 70 will be there. Some 70's have a bog off-idle and I think the modification on the slide to correct it is also on the website. Jon
December 29, 201015 yr Ya need a bigger main jet... Fit a 100 and that will help, I fitted a 105, sorted it straight away
December 29, 201015 yr Hi I had all sorts of issues with my sons 50 boy, I stripped the carb, checked the reeds, put all back together and still the bog.... really could not figure it out, played with air screw etc........ then..... I changed the plug and all started running right !!!! I would definitely try a new plug as it did the trick for me although already seems to have gone through another one so just about to change the plug cap and put in one of the platinum plugs to see if it lasts a little longer. Cheers
January 12, 201115 yr Author cheers guys put a new plug in it and it run fine straight away also played around with the carb and it running good
