December 30, 201015 yr Hi, does anybody know the difference between the 4rt and crf250 engine? cylinder-head, drivedrain....
December 30, 201015 yr gears are different bore and stroke are not the same camshaft and flywheel are different best regards bob
December 30, 201015 yr The head is different also. The valve adjustment for the crf is shim under bucket. The 4rt uses threaded adjusters.
