January 5, 201115 yr doing the fork seals on my evo anyone know the weight of the standard oil? im about to use pj1 05
January 5, 201115 yr doing the fork seals on my evo anyone know the weight of the standard oil? im about to use pj1 05 Hi I think most people use 5w some people dabble with 10w if they are a bit on the heavy side! Rij
January 5, 201115 yr I think the manual says Bardahl or Bel-Ray 5wt. All 5wts are not the same. They all have a different centistoke value even if the bottle says 5wt. Use this chart to get an oil thats close to the oem oil. http://www.pvdwiki.c...uspension_Fluid
January 5, 201115 yr Author Hi I think most people use 5w some people dabble with 10w if they are a bit on the heavy side! Rij cheers rij i,ll probably just go with the 5w then. the manual called for oj01 and i just wanted to know what this was. thanks for the reply.
January 5, 201115 yr Author I think the manual says Bardahl or Bel-Ray 5wt. All 5wts are not the same. They all have a different centistoke value even if the bottle says 5wt. Use this chart to get an oil thats close to the oem oil. http://www.pvdwiki.c...uspension_Fluid cheers liviob just checked page 49 on the manual. as per your post no joy on your link though.im kinda hoping the pj1 is a little heavier. but will use it now ive got it thanks.
January 6, 201115 yr Try this link. This chart will take most of the guess work out of suspension tuning. I found approxamatly 1 1/2 to 2 centistokes change equals one click adjustment on japanese forks. http://www.pvdwiki.com/index.php?title=Suspension_Fluid Edited January 6, 201115 yr by Liviob
January 6, 201115 yr Author Try this link. This chart will take most of the guess work out of suspension tuning. I found approxamatly 1 1/2 to 2 centistokes change equals one click adjustment on japanese forks. http://www.pvdwiki.com/index.php?title=Suspension_Fluid wow! cant believe the difference in cenistroke from brand to brand.great chart
