January 12, 201115 yr hi i have a 2005 280cc gas gas txt pro and was wondering how much oil to mix with 5 litres of petrol as ive been told a few different figures? thanks
January 12, 201115 yr Author ok mate thanks ive been told 50:1 and 80:1 but ill go with wot u said cheers mate
January 12, 201115 yr Hi I use 60-1 and my pro runs fine. Personally I worry about reducing the amount of oil to 70-1 I just think it is too little to provide sufficient lubrication. Am I right or wrong? Who can say, I just feel comfortable with this mix ratio and don't think there is any gain from running less oil. But I always use Super Unleaded (Shell if I can get it). Rather that listen to our personal views just phone Gas Gas UK at least you will get told what the manufacturers recommend. Martin
January 13, 201115 yr It depends on what type of mix oil you use, synthetic oil mix 80:1 if you are using standard mix oil mix 60:1
January 15, 201115 yr It depends on what type of mix oil you use, synthetic oil mix 80:1 if you are using standard mix oil mix 60:1 I have mixed 100:1 in my last 3 gasgas trials bikes ipone oil never had any problems
