January 12, 201115 yr hi all i got a problem with my boys gas gas 70 rookie 2003 model i got oil spitting out of the exhaust onto the back wheel and brake what causes this and how do i stop it thanks
January 12, 201115 yr Sounds like a fairly minor problem. If the bike gets used at low gears/revs much of the time, the 2t oil is not being burned off and has over time saturated the silencer packing. Once it is wet with oil it will never dry out and the only place for the excess oil to go is out the end. From here it drips down onto the brakes. etc Try repacking the silencer.
January 13, 201115 yr Mix Ratio? I'd run in the range of 50-60:1, full-synthetic premix oil. The smaller engines run a little hotter and can develop localized hot spots. Jon Edited January 13, 201115 yr by JSE
